I ordered some electrodragon boards and they are marked as V 2-2. They look different to the pictures elsewhere and appear to have a problem with the E line.
My existing setup works fine with the adafruit bonnet, so I know the matrix boards are good.
With the electrodragon boards I get the ‘missing band’ you’d expect without the E line.
After trying every conceivable option combination with the test/demos I put a logic analyser on the output and found there’s no E line signal on pin 4 or 8, regardless of jumper configurations.
Checking the board the traces from the ‘E_buf’ pads go directly to pin 4 - this confirmed visually and with a circuit tester.
Checking with a scope, there’s no signal on any of the jumper pads - they’re floating/ground.
Has anyone encountered this?
I can’t help feeling I’ve missed something… however the logic/scope/tester make me think something’s astray… and all of the 3 boards I received are the same.
Any thoughts, help, insight or comment welcome!
(The pic of the back of the board clearly shows the line from the E_buf jumper pad to pin 4)
