Fabulux platinum compatiblity
Hello there,
I would like to ask some help. I did development 5 years ago which based on this library.
Now I have to do it again, but a landscape changed a little.
The panel which I have to work with is Fabulux platinum series. I am wondering is it possible to power this panel with this library?
This say nothing about the panel specification. Do you have a link or picture of the exact your panel? - not to an advertisement on the site?
The attached URL is the only thing I know about the panel so far.
The panel on the image looks like it doesn’t have a HUB75 connector. If so, it will be difficult to run it with this library
That I know. The customer said, it doesn’t use flexible cables to connect the panels to eachother.
I got some pictures of the connector on the panel. based on this I think this library wont work.
Based on the picture the panel is equipped with NovaStar receiving card with Ethernet connection.
It definitely is not compatible with the library.
Well, that it life I guess.
Do you know maybe any other libraries which could work?
no, I never work with such panels
