The panel on the left appears to have color inversion. I tried switching the panels, no dice.
Hi Natalie,
It will be easier for us to help you if you give more details about your problem.
Basically, your hardware configuration and which command you run.
This is my hardware config, its a Pi 4 with the new adafruit bridge.
I’m using the led-image-viewer command.
I’ve never used adafruit hat, but I’ll try to help you.
Your command should be something like this :
sudo ./led-image-viewer yourimage.png --led-rows=32 --led-cols=64 --led-chain=2 --led-gpio-mapping=adafruit-hat --led-multiplexing=?
Did you try each value of led-multiplexing ?
