RUC7258D P3 RGB board
Hi Team,
I mistakenly bought this RUC7258D P3 board from https://hubtronics.in; (main driver is CNS7263GP [https://m.isle.org.cn/news/detail/enterprises?lang=zh&id=554\]) and now not able to use it with Pi 4B & Adafruit RGB Matrix Bonnet. Tried all the options, but so far nothing worked.
Any help would be useful.
As I already wrote, I don’t have a solution to your problem.
I only wanted to point out something else: you always refer to your panel as a “RUC7258 board”. This isn’t entirely accurate. The RUC7258 chip is a row switcher. There’s nothing special about this chip and it’s supported by all known libraries.
What’s causing problems with your panel is the CNS7263 driver. Therefore, it would be better to change the thread title and ask about the “CNS7263GP board”, making your thread easier to find for anyone encountering the same problem.
I’m unable to edit the post. I ended up ordering an “HD-D16 Full Colour Asynchronous LED Display Controller Card”. I shall post if it works with that controller.
I bought an HD-D16 controller by Huidu company and the panel worked with it. I used HDPlayer software to set it up. Driver CNS7263, Decoding 138.
after that I tried to reverse engineer and look at the Latch and Clock pins on ESP32 serial monitor.
#include <Arduino.h>
#include "driver/pcnt.h"
#define LAT_PIN 4
#define CLK_PIN 16
// Buffer to hold the secret sequence
#define MAX_SEQS 300
volatile int16_t recorded_pulses[MAX_SEQS];
volatile int seq_index = 0;
// Interrupt triggers ONLY when Latch drops to LOW (End of a command)
void IRAM_ATTR lat_isr() {
  int16_t count = 0;
  // 1. Instantly pull the hardware count
  pcnt_get_counter_value(PCNT_UNIT_0, &count);
  // 2. Clear the hardware counter for the next latch
  pcnt_counter_clear(PCNT_UNIT_0);
  // 3. Filter out normal row data (1 clock) and huge VSYNC overloads (1000+ clocks)
  if (count > 2 && count < 1000) {
    if (seq_index < MAX_SEQS) {
      recorded_pulses[seq_index] = count;
      seq_index++;
void setup() {
  Serial.begin(115200);
  delay(1000);
  Serial.println("\n--- ESP32 HARDWARE (PCNT) WIRETAP ACTIVE ---");
  Serial.println("Waiting for HD-D16 boot sequence...");
  pinMode(LAT_PIN, INPUT_PULLDOWN);
  pinMode(CLK_PIN, INPUT_PULLDOWN);
  // ESP32 HARDWARE PULSE COUNTER CONFIGURATION
  // This counts 20MHz signals natively without crashing the CPU
  pcnt_config_t pcnt_config = {
    .pulse_gpio_num = CLK_PIN,
    .ctrl_gpio_num = LAT_PIN,
    .lctrl_mode = PCNT_MODE_DISABLE, // Disable counting when LAT is LOW
    .hctrl_mode = PCNT_MODE_KEEP,    // Keep counting when LAT is HIGH
    .pos_mode = PCNT_COUNT_INC,      // Increment on CLK rising edge
    .neg_mode = PCNT_COUNT_DIS,      // Ignore CLK falling edge
    .counter_h_lim = 32767,
    .counter_l_lim = -1,
    .unit = PCNT_UNIT_0,
    .channel = PCNT_CHANNEL_0,
  pcnt_unit_config(&pcnt_config);
  pcnt_counter_pause(PCNT_UNIT_0);
  pcnt_counter_resume(PCNT_UNIT_0);
  // Attach a lightweight interrupt to read the hardware counter when Latch falls
  attachInterrupt(digitalPinToInterrupt(LAT_PIN), lat_isr, FALLING);
// Variables to detect when the burst of commands is finished
int last_seq_index = 0;
uint32_t last_change_time = 0;
void loop() {
  int current_index = seq_index;
  if (current_index != last_seq_index) {
    last_seq_index = current_index;
    last_change_time = millis();
  // If we collected data and 1 FULL SECOND has passed with no new commands...
  if (current_index > 0 && (millis() - last_change_time > 1000)) {
    noInterrupts(); // Pause briefly to copy data safely
    int count = seq_index;
    int16_t temp_array[MAX_SEQS];
    for(int i = 0; i < count; i++) temp_array[i] = recorded_pulses[i];
    // Reset trackers for next time
    seq_index = 0;
    last_seq_index = 0;
    interrupts();
    Serial.println("\n[!] INTERCEPTED CONFIGURATION BURST [!]");
    Serial.print("LAT HIGH + CLK Pulses: ");
    for (int i = 0; i < count; i++) {
      Serial.print(temp_array[i]);
      Serial.print(", ");
    Serial.println("\n-------------------------------------------");
this is the sequence I get. not only during booting, but even after that.
12:47:02.441 -> [!] INTERCEPTED CONFIGURATION BURST [!]
12:47:02.441 -> LAT HIGH + CLK Pulses: 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 11, 26, 14, 4, 26, 14, 6, 26, 12, 9, 30, 10, 26, 14, 4, 26, 14, 6, 26, 14, 9, 26, 14, 10, 26, 14, 4, 36, 8, 37, 8, 26, 14, 10, 34, 29, 14, 26, 14, 8, 35, 10, 28, 10, 4, 26, 14, 6, 33, 8, 29, 19, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 13, 10, 26, 14, 4, 39, 6, 29, 15, 26, 14, 10, 36, 4, 29, 10, 29, 9, 26, 14, 10, 26, 14, 4, 27, 12, 6, 26, 14, 8, 28, 11, 10, 28, 11, 4, 26, 14, 7, 26, 14, 8, 37, 10, 26, 14, 4, 31, 7, 26, 13, 8, 26, 13, 10, 31, 4, 29, 13, 26, 14, 8, 26, 14, 10, 33, 4, 26, 14, 6, 41, 8, 29, 11, 32, 4, 38, 6, 29, 10, 27, 12, 10, 29, 5, 34, 6, 29, 14, 26, 12, 10, 29, 10, 4, 29, 13, 26, 14, 8, 37, 10, 29, 6, 26, 14, 6, 39, 8, 26, 14, 10, 26, 12, 4, 26, 14, 6, 29, 10, 28, 10, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 27, 11, 10, 36, 4, 26, 14, 6, 26, 14, 9, 37, 10, 29, 7, 26, 14, 7, 30, 9, 26, 12, 10, 26, 14, 4, 27, 11, 7, 29, 13, 26, 14, 10, 29, 10, 4, 40, 6, 29, 12, 26, 14, 10, 30, 5, 29, 11, 29, 11, 29, 13, 29, 10, 26, 14, 6, 26, 14, 8, 26, 14, 10, 29, 9, 4, 26, 14, 6, 26, 14, 9, 26, 14, 10, 26, 14, 4, 35, 7, 43, 9, 26, 14, 10, 32, 4, 26, 14, 7, 27, 12,
12:47:02.542 -> -------------------------------------------
12:47:05.361 ->
12:47:05.361 -> [!] INTERCEPTED CONFIGURATION BURST [!]
12:47:05.361 -> LAT HIGH + CLK Pulses: 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 30, 9, 29, 15, 26, 14, 4, 26, 14, 6, 33, 8, 26, 14, 11, 36, 4, 35, 6, 33, 9, 34, 11, 29, 12, 26, 13, 6, 30, 9, 29, 16, 26, 12, 4, 26, 14, 8, 38, 9, 26, 14, 10, 26, 14, 4, 33, 7, 30, 8, 30, 10, 26, 14, 4, 29, 14, 26, 14, 8, 26, 14, 10, 29, 11, 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 13, 4, 26, 14, 6, 26, 13, 8, 29, 16, 26, 13, 4, 38, 6, 26, 12, 8, 26, 14, 10, 29, 8, 26, 14, 6, 26, 14, 8, 26, 14, 10, 29, 10, 4, 26, 14, 6, 26, 14, 8, 35, 10, 29, 7, 26, 14, 6, 26, 14, 8, 22, 24, 26, 12, 4, 29, 13, 26, 14, 8, 26, 14, 10, 26, 12, 4, 26, 14, 7, 26, 14, 8, 26, 13, 10, 29, 13, 29, 11, 26, 14, 8, 29, 16, 26, 14, 4, 37, 6, 29, 11, 29, 14, 26, 14, 4, 33, 6, 29, 15, 26, 14, 10, 39, 4, 38, 6, 26, 14, 8, 34, 10, 29, 11, 30, 6, 35, 8, 29, 19, 26, 12, 4, 26, 14, 6, 27, 12, 8, 29, 15, 26, 14, 4, 26, 14, 6, 28, 10, 8, 26, 14, 10, 26, 14, 4, 29, 15, 26, 13, 8, 29, 13, 28, 11, 4, 26, 13, 7, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 12, 4, 33, 6, 26, 14, 8, 26, 14, 10, 31, 4, 29, 10, 6, 26, 14, 8, 29, 17, 29, 8,
12:47:05.466 -> -------------------------------------------
12:47:08.276 ->
12:47:08.276 -> [!] INTERCEPTED CONFIGURATION BURST [!]
12:47:08.276 -> LAT HIGH + CLK Pulses: 26, 14, 4, 26, 14, 7, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 29, 10, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 39, 4, 29, 8, 38, 8, 26, 14, 10, 29, 5, 27, 11, 6, 32, 8, 29, 10, 10, 26, 12, 4, 26, 14, 6, 29, 13, 28, 10, 10, 26, 14, 4, 26, 14, 6, 31, 8, 26, 14, 10, 31, 4, 29, 9, 6, 26, 14, 8, 26, 14, 10, 29, 8, 27, 11, 7, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 13, 7, 34, 8, 26, 14, 10, 41, 4, 31, 6, 29, 14, 35, 10, 39, 4, 29, 14, 26, 14, 8, 29, 9, 10, 26, 12, 4, 26, 12, 6, 26, 13, 8, 36, 10, 29, 9, 4, 26, 14, 6, 29, 11, 29, 14, 26, 14, 4, 29, 9, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 7, 26, 14, 8, 40, 10, 27, 11, 4, 26, 14, 7, 26, 14, 8, 26, 14, 10, 43, 4, 26, 14, 7, 29, 15, 29, 17, 28, 10, 4, 29, 9, 7, 29, 15, 26, 14, 10, 26, 14, 4, 31, 7, 26, 13, 8, 26, 13, 10, 40, 4, 32, 6, 33, 8, 37, 10, 26, 14, 4, 34, 6, 29, 9, 8, 26, 12, 10, 26, 14, 4, 30, 6, 29, 16, 26, 13, 11, 26, 14, 4, 29, 26, 13, 8, 26, 14, 10, 29, 9, 29, 11, 26, 13, 9, 26, 12, 10, 26, 14, 4, 26, 14, 6, 26, 13, 8, 26, 14, 10, 26, 14, 4, 34, 7, 26, 14, 8, 26, 14, 10, 32, 4, 29, 13, 26, 12, 8, 32, 10, 26, 14, 4, 26, 14, 7,
12:47:08.346 -> -------------------------------------------
12:47:11.148 ->
12:47:11.148 -> [!] INTERCEPTED CONFIGURATION BURST [!]
12:47:11.148 -> LAT HIGH + CLK Pulses: 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 12, 26, 14, 8, 29, 18, 26, 14, 4, 26, 14, 6, 26, 12, 8, 26, 14, 11, 39, 4, 37, 6, 29, 10, 9, 26, 14, 10, 30, 4, 43, 7, 26, 14, 9, 29, 14, 29, 9, 26, 12, 8, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 14, 4, 31, 6, 26, 14, 8, 35, 10, 28, 11, 4, 29, 11, 26, 14, 8, 31, 10, 28, 10, 4, 26, 14, 6, 38, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 29, 14, 32, 10, 33, 4, 29, 12, 26, 14, 8, 28, 11, 10, 26, 14, 4, 26, 14, 7, 26, 14, 8, 36, 10, 26, 14, 4, 26, 13, 7, 31, 8, 29, 16, 26, 14, 4, 29, 7, 29, 16, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 31, 10, 26, 14, 4, 36, 6, 29, 12, 29, 17, 26, 14, 4, 29, 13, 29, 16, 26, 14, 10, 26, 14, 4, 26, 14, 7, 26, 14, 8, 37, 10, 29, 6, 26, 14, 7, 26, 14, 8, 29, 17, 26, 14, 4, 27, 11, 7, 29, 16, 26, 14, 10, 26, 14, 4, 27, 11, 6, 26, 14, 8, 26, 14, 10, 26, 14, 4, 29, 8, 26, 14, 8, 26, 13, 10, 29, 10, 26, 14, 6, 32, 8, 29, 15, 29, 9, 26, 13, 6, 41, 8, 26, 14, 10, 26, 14, 4, 34, 6, 32, 8, 26, 14, 11, 26, 14, 4, 29, 10, 6, 26, 14, 9, 29, 11, 26, 14, 4, 26, 12, 6, 26, 11,
12:47:11.262 -> -------------------------------------------
12:47:14.075 ->
12:47:14.075 -> [!] INTERCEPTED CONFIGURATION BURST [!]
12:47:14.075 -> LAT HIGH + CLK Pulses: 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 29, 12, 26, 14, 10, 26, 14, 4, 32, 6, 26, 14, 8, 26, 14, 10, 29, 9, 29, 14, 26, 14, 8, 29, 13, 29, 9, 26, 14, 6, 36, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 40, 4, 31, 6, 43, 8, 26, 14, 10, 29, 9, 4, 26, 14, 6, 26, 14, 8, 29, 14, 26, 14, 4, 26, 14, 7, 38, 8, 32, 10, 26, 14, 4, 37, 6, 31, 8, 29, 18, 31, 4, 29, 11, 26, 14, 8, 26, 14, 10, 29, 7, 26, 14, 7, 26, 14, 8, 29, 15, 26, 14, 4, 26, 14, 6, 26, 14, 8, 29, 14, 26, 14, 4, 26, 14, 6, 26, 14, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 29, 9, 8, 26, 14, 10, 26, 14, 4, 26, 14, 6, 40, 8, 29, 12, 26, 14, 4, 26, 14, 6, 29, 13, 27, 11, 10, 26, 14, 4, 29, 8, 26, 14, 8, 26, 14, 10, 26, 13, 4, 26,ets Jul 29 2019 12:21:46
12:47:14.725 ->
Though not prominent, there is a pattern like
26, 14, 4
26, 14, 6
26, 14, 8
26, 14, 10
Hi !
I don’t understand what this pattern is and how this knowledge will help launch the panel.
I thought those will be the start sequence with A, B, C, & D decoder. but it did not work. I only could do this much. Could not progress any further.
There’s no need to decipher the ABCD decoder’s operation this way; it’s standard and has long been supported by the library.
As I already wrote, the problem with your panel isn’t the decoder, but the CNS7263 driver. To do reverse engineering the protocol, you at least need a logic analyzer to capture the driver’s pulse signals in different modes. By studying these diagrams, one can try to create a description of the protocol, for example, as in the message: Master Bug: PWM panel support and spec sheets for DP32020A DP3264S DP3269S DP3364S DP3367S_CN DP3369S FM6373 iCN2038S ICN2053 MBI5038 MBi5152 MBI5153 MBI5253 MBI5264 MBI5353 · Issue #466 · hzeller/rpi-rgb-led-matrix · GitHub
However, the pulse diagrams and driver parameters are just the beginning; next, based on them, it will be necessary to write code that emulates the operation of the HD-D16 controller.
I would recommend to you to read these two threads:
Do you have any idea why each vendor feels the need to make an incompatible chip and driver for each PWM panel? I mean what the hell?
Are they literally trying to make those panels as difficult and unwelcome to use as possible?
Same question for @kingdo9 if you happen to know. I simply don’t get it
