P2.5 128x64 IC SM16380 HUB75e
Hi all,
Lost Beginner here. So below is my setup:
  • RPI3B
  • Adafruit RGB Matrix HAT + RTC
  • P2.5-2121-128x64-32S LED Panel (using IC SM16380)
when i run the ./demo -D 0 and regardless of what Options i’d used, I’m just seeing lines on the LED Screen.
Imgur
I’m kinda lost in how should i troubleshoot this. Can I get some guidance/help from the gurus? Thank You.
Unfortunately, no way.
This panel equipped with new generation S-PWM driver 16380, which is incompatible with current code of the library.
Hi there,
Thanks for the update. Looks like I’d need to reinvest in older model Boards.
