For all your C++ 2D code, I should plug this again:
- use my Framebuffer::GFX to write 2D code against GitHub - marcmerlin/Framebuffer_GFX: Framebuffer::GFX is base Class for SmartMatrix::GFX, NeoMatrix::GFX, FastLED_SPITFT_GFX, FastLED_RPIRGBPanel_GFX, FastLED_TFTWrapper_GFX, and more · GitHub
- you can compile that same code natively and display on linux with Marc's Blog: arduino - Running Arduino code with 2D FastLED, Adafruit::GFX, and LEDMatrix displays on Linux and GitHub - marcmerlin/ArduinoOnPc-FastLED-GFX-LEDMatrix: Run code for SmartMatrix, Adafruit-GFX-Library, FastLED (2D), and LEDMatrix on linux/Raspberry Pi with X11, SDL, or on top of RGBPanels · GitHub
- on rPi Marc's Blog: arduino - Running FastLED, Adafruit::GFX, and LEDMatrix code on High Resolution RGBPanels with a Raspberry Pi and GitHub - marcmerlin/FastLED_RPIRGBPanel_GFX: Run Arduino Code on rPi and display a FrameBuffer::GFX display on an RGBPanel at higher resolution than arduino chips, can · GitHub
Basically my code written against Framebuffer::GFX , I type make on linux, it builds natively and displays with SDL.
On rPi, I type make it displays with rpi-rgb-led-matrix.
For ESP32, I built with arduino and it builds on top of the ESP32 DMA driver
I have drivers for arduino TFTs, neopixel arrays, also added RP2350 RGBPanel support
