Hi I have a panel that cannot be used with the library and I came to the conclusion that it is because the mapping of LEDs is different from those configured in it. Previously I used identical panels but with the addresses A,B,C and D and these new panels only have A,B and C. I was also able to control them with a NovaStar controller but my goal is to do it with an RPI4.
Through this board I was able to obtain this following images
in which you can see the mapping of the LEDs.
My question is, how do I map the leds correctly to be able to use these panels with the library?
