I have a 64x64 RGB Panel from Joy-IT and is flickering
Here the back from the panel
Datasheet
and the Manuel
I have a extension board from joy-it
What I’m doing wrong?
You didn’t say even a word about what are you doing with it?
Please describe your project. What about the connection?
Could you show your code?
I test only the examples of the api…
sudo examples-api-use/demo -D 0 --led-rows=64 --led-
cols=64
cols64 --led-slowdown-gpio=2
and the text scroller
sudo ./text-scroller -f ../fonts/9x18.bdf --led-rows=64 --led-cols=64 blah
can you show a video of the flicker?
does your board/setup work with another panel?
what Pi are you using (hopefully not a pi0v1 or p1 or pi2)
did you follow the directions in the README to turns off sound and other stuff that can cause flickering?
should be blah with a raspberry pi 4b not used with a other panel
Have you tried adding –led-slowdown-gpio=4=4 ?
