I’m using a RPi Zero 2W and either a 64x64 or two 128x64 matrices (ran as 128x128 with vmap on the adafruit hat). Both of these setups work with the Adafruit Bonnet, but only when I supply the 5v power to the bonnet. If I supply power directly to the matrix (and power over USB to the Pi), Demo 0 results in red lines flashing all over instead of behaving like normal.
I’m using this female DC adapter from adafruit when supplying the power directly.
I’m looking for help with two things:
Firstly I’d love help diagnosing why the matrix misbehaves when directly supplied with power, especially since it works flawlessly when the power supply is plugged directly into the adafruit bonnet.
Secondly, I’m not entirely sure how to supply power directly to the hardwaredragon adapter - I soldered the supplied 8.5mm connectors and used the above mentioned female DC adapter (and some extra wire I had) to supply power to the board, but my Pi isn’t lighting up when I do that. Are there any additional steps I need to take for the adapter to supply power to the Pi?
Thanks! I can provide photos of any connectors etc. as well if that would be helpful.
