I am currently working on a project using the Raspberry Pi Zero W V1, and I have a few questions regarding the setup of my hardware.
Could you kindly provide a detailed map or diagram showing where to place the pins on the Raspberry Pi Zero W V1? Specifically, I would appreciate guidance on how to connect the various components, such as the LED matrix, to the appropriate GPIO pins on the Raspberry Pi.
Additionally, I would like some clarification on the power supply setup. When connecting the power supply adaptor to the Raspberry Pi Zero W, should both fork connectors be inserted into the positive (VCC) and negative (GND) slots on the power supply adaptor, or is there a different configuration I should follow?
