Hey there,
The screen I am using is in a remote location, which is hard to reach.
Can I check somehow if it works or not via ssh?
Thanks for the tips!
Hey there,
no, it’s blind, you send data and get no feedback as to whether it worked
makes sense. thats what I thoungh.
Maybe with an additional power monitoring.
OK, is there a way to generate a BMP file (or similar) of what has been sent thanks to the library ? That would allow to make a “fake” rendering at least to give a feedback of what it “should” look like
you can dump the canvas which is an array of RGB888 (24bit), add a PPM header and dump a PPM file.
Thanks for this quick and positive answer. That would be very straightforward.
Any hint on how to dump the canvas array, if possible using python bindings ?
Johan
Have a look at examples-api-use/ledcat.cc, it does the opposite but should be close enough
