Hey, i have 3 different RGB LED panel with 192 Height and 448 Width. Is it possible to connect them together with one Raspberry Pi ? Which Pi should i use?
what do they look like? spec sheet? plug?
Either way, a single of those panels is 86K pixels, you cannot reasonably run this with a single channel. You’d need to make multiple channels per panel (and I’m assuming what you call a panel is really a bunch of panels chained together?)
