Adafruit 32x32 Matrix barely working
Hello everyone,
I’m trying to work on a relatively simple game project with a single 32x32 matrix by Adafruit ( P5-2121-32×32-16S-HL1.0). Unfortunately, I have now run into an issue while trying to hookup the panel to my Raspberry Pi 4B.
For technical reasons I can’t use a shield/hat to hookup the matrix so I’ve connected the HUB75 cable directly to the Pi’s pins using the standard pin schematic provided by the library’s documentation.
Now my issue is that no matter what I do, the matrix is only displaying seemingly random pixels.
When I plug it in it looks like the image on the left. Colors and position of the pixels randomly change when unplugging the HUB75 cable and plugging it back in.
Now when I run one of the example programs from the library what can be seen in the center image happens.
(The command being used here is sudo ./demo -D 0 --led-gpio-mapping=regular --led-slowdown-gpio=2 --led-scan-mode=1 --led-cols=32 --led-rows=32)
The half of the display below or above of the previously activated pixels get lit up in the same color of the original pixels. This happens regardless of what code is being run or what settings are used while running. The only difference I could observe appears when inputting a different amount of LED rows which slightly changed the amount of pixels lighting up.
When exiting the program the pixels get reset to the state seen on the right image.
They just move down to the bottom of the previously lit up area. If I run a program again now, the half above these pixels gets lit up.
My best guess currently would be, that the output of the Pi gets misinterpreted because of a difference in voltage, but even then this behaviour seems not very fitting to me. Before I go and buy a level switcher and change up my whole setup I would just like to know if anyone more experienced than me has some other ideas. Thank you :slight_smile:
it may or may not work without level shifters
Since you have not confirmed your panels even work, get yourself an electrodragon active 3 board, make sure the pi and panels work, even if you won’t be able to use the shield later, at least you will validate everything else
Hi, thanks for your response. I have since bought an Adafruit RGB Matrix Bonnet and tried the same thing on two different matrices and two different RasPis, all with similar results. The Bonnet has changed the display slightly but it’s still just some LEDs lighting up with no recognizable pattern.
Figured I should post my solution here if anyone ever has a similar issue:
I got the matrix to work correctly via the bonnet after enabling the “quality option” and soldering GPIO4 and GPIO18 together (see this section in the Adafruit guide).
reminder that an active-3 pre-wired board that just works, is less than $10 shipped form electrodragon and barely more from adafruit. Hand wiring is not worth your time anymore :slight_smile:
