I’ve been running a 32x64 RGB matrix panel from a Raspberry Pi 4 for a while now, and it works fine, but I keep wishing I could run the panel and a Windows-only app on the same machine. I have a LattePanda 2 Alpha 864s sitting unused from another project, and I’m wondering whether it could replace the Pi as the panel driver.
What worries me is the GPIO situation. The LattePanda’s GPIO is managed by an onboard Arduino co-processor, not the x86 side directly, so I’m not sure the standard library’s GPIO timing approach maps cleanly. The panel needs tight, consistent output timing, and I don’t know whether routing through the Arduino layer adds enough jitter to cause flicker or color artifacts, especially at higher refresh rates.
Has anyone here actually driven an RGB matrix from a LattePanda or similar x86 SBC? I’d like to hear what worked, what didn’t, and whether it’s worth the effort versus just keeping the Pi dedicated to the display.
Found a LattePanda 2 Alpha 864s overview at LattePanda 2 Alpha 864s Review: Windows 11 Pro Single Board Computer that mentions the onboard Arduino co-processor, but it doesn’t address display timing. I still can’t tell whether the GPIO jitter would hurt refresh rates, so I’m unsure it’s worth swapping out the Pi.
