Hi there,
I got my first RGB LED Matrix (https://aliexpress.com/item/32757647402.html) paired with the Adafruit (Adafruit RGB Matrix Bonnet for Raspberry Pi : ID 3211 : $14.95 : Adafruit Industries, Unique & fun DIY electronics and kits) up and running and so far it’s been a blast creating various programs for it. I also have a 5V 15A power supply plugged into the Bonnet.
But the panel is surprisingly dim. Based on my testing, the LEDs can sustain being very bright for quite long.
Currently I am achieving 110Hz when driving the full panel with just about any python program, even when there are some relatively heavy calculations in each loop.
The options I am using are below. If I for example use rows=8 and cols=16 I can achieve 960Hz, each individual pixel gets a lot brighter (in this case specifically presumably because each pixel gets adressed multiple times?).
The python program looks roughly like this:
import numpy as np
import rgbmatrix
options = rgbmatrix.RGBMatrixOptions()
options.rows = 64
options.cols = 64
options.show_refresh_rate = 1
options.pwm_lsb_nanoseconds = 80
options.led_rgb_sequence = "RBG"
options.hardware_mapping = "adafruit-hat"
arr = np.zeros((64,64,3), np.uint8)
while True:
arr.fill(0)
arr[:16,:16] = np.array([255,110,0])
canvas.SetImage(Image.fromarray(arr).convert('RGB'))
matrix.SwapOnVSync(canvas)
I am not specifically looking for a way to get a higher refresh rate, as 110Hz is easily enough for anything I have in mind. Is there instead anything I can do to get the full brightness out of my panel?
Any help is appreciated, thanks.
