I hope someone can help, I have some modules which have the SM16380SA driver chip (172x86 display). I used a fresh OS install and used Kingdo9’s GitHub repository to install everything, I am able to get the modules to display, however if I run D0 using the following:
sudo examples-api-use/demo --led-rows=128 --led-cols=43 --led-chain=3 --led-parallel=1 -D0 --led-no-busy-waiting --led-spwm-row-addr-type=1 --led-panel-type=sm16380sh --led-spwm-scan=0 --led-multiplexing=0
I’ve tried the various Multiplexing options as well and the various spwm options, but the best I can get it is:
This one looks like the verical is correct, but the horizonal is reversed, I got this by running:
examples-api-use/demo -D0 --led-panel-type=icnd1065l --led-rows=86 --led-cols=172 --led-spwm-row-addr-type=2 --led-spwm-scan=0 --led-spwm-register-config=0 --led-parallel=1
I have also tried adjusting the chain length, the other various chip configurations, Some of them work, but the result is not as good as the above example. If anyone has been able to run the SA version of the driver successfully, and could point me in the right direction, I would really appreciate it.
Thanks !
