Hi everyone, I’m new to the hardware side of things and I’ve been trying to get a 128x64 led matrix with ICN2037BP set up with an adafruit + HAT. The output is similar to what is described in this issue but I don’t understand the solution. It’s also not used in an adafruit HAT so I’m curious if how I can translate it to work with the HAT. Any help would be appreciated because I’m going a little nuts with this.
The display output is exactly the same as the first picture in that issue.
