Hi All,
Im really new with everything matrix/raspberry/python. I have got panels working and using imagine viewer and all the examples.
What im trying to get working now is using the same logic as a program called Pimarquee2 that displays automatically on the PI4 second HDMI display.
I have changed the code to point to led-image-viewer instead of the omxplayer.
Can anyone give some pointers on how to get this working?
Or suggest another way with the working result? perhaps a way to copy whatever is displaying on the second HDMI port and display on the LCD’s?
thanks in advance!
here is the script i have been changing - credit to Loosernator built built the script on Github.
#!/usr/bin/python3
import os
from subprocess import *
from time import *
import xml.etree.ElementTree as ET
INTRO = “/home/pi/PieMarquee2/intro.mp4”
INTRO = “/home/pi/PieMarquee2/intro.png”
for DPI screen
#VIEWER = “/opt/retropie/configs/all/PieMarquee2/omxiv-marquee /tmp/marquee.txt -f -b -d 4 -t 5 -T blend --duration 900 > /dev/null 2>&1 &”
for Pi4 hdmi1
#VIEWER = “/opt/retropie/configs/all/PieMarquee2/omxiv-marquee /tmp/marquee.txt -f -b -d 7 -t 5 -T blend --duration 900 > /dev/null 2>&1 &”
#Tesing line for imageviewer software
VIEWER = “/opt/retropie/configs/all/PieMarquee2/led-image-viewer /tmp/marquee.txt --led-no-hardware-pulse --led-rows=32 --led-cols=64 --led-chain=2 --led-slowdown-gpio=2 --led-gpio-mapping=adafruit-hat &”
arcade = [‘arcade’, ‘fba’, ‘mame-advmame’, ‘mame-libretro’, ‘mame-mame4all’]
def run_cmd(cmd):
runs whatever in the cmd variable
p = Popen(cmd, shell=True, stdout=PIPE)
output = p.communicate()[0]
return output.decode()
def kill_proc(name):
ps_grep = run_cmd("ps -aux | grep " + name + “| grep -v ‘grep’”)
if len(ps_grep) > 1:
os.system("killall " + name)
def is_running(pname):
ps_grep = run_cmd(“ps -ef | grep " + pname + " | grep -v grep”)
return True
else:
return False
def get_publisher(romname):
filename = romname+".zip"
publisher = “”
for item in root:
if filename in item.findtext(‘path’):
publisher = item.findtext(‘publisher’)
break
if publisher == “”:
return “”
words = publisher.split()
return words[0].lower()
if os.path.isfile(INTRO) == True:
## for DPI screen
#run_cmd("omxplayer --display 4 " + INTRO)
## for Pi4 hdmi1
run_cmd("omxplayer --display 7 " + INTRO)
## for LED
run_cmd("led-image-viewer --led-no-hardware-pulse --led-rows=32 --led-cols=64 --led-chain=2 --led-slowdown-gpio=2 --led-gpio-mapping=adafruit-hat " + INTRO )
doc = ET.parse("/opt/retropie/configs/all/PieMarquee2/gamelist_short.xml")
root = doc.getroot()
if os.path.isfile("/home/pi/PieMarquee2/marquee/system/maintitle.gif") == True:
## for DPI screen
#os.system(“omxplayer --loop --no-osd --display 4 /home/pi/PieMarquee2/marquee/system/maintitle.mp4 &”)
## for Pi4 hdmi1
os.system(“omxplayer --loop --no-osd --display 7 /home/pi/PieMarquee2/marquee/system/maintitle.mp4 &”)
## for LED added into script
os.system(“led-image-viewer -C /home/pi/PieMarquee2/marquee/system/maintitle.png --led-no-hardware-pulse --led-rows=32 --led-cols=64 --led-chain=2 --led-slowdown-gpio=2 --led-gpio-mapping=adafruit-hat &”)
else:
os.system(“echo ‘/home/pi/PieMarquee2/marquee/system/maintitle.png’ > /tmp/marquee.txt”)
os.system(VIEWER)
cur_imgname = “system/maintitle”
while True:
sleep_interval = 1
ingame = “”
romname = “”
sysname = “”
pubpath = “”
instpath = “”
imgpath = “”
ps_grep = run_cmd(“ps -aux | grep emulators | grep -v ‘grep’”)
if len(ps_grep) > 1: # Ingame
ingame=""
words = ps_grep.split()
if ‘advmame’ in ps_grep:
sysname = “arcade”
romname = words[-1]
else:
pid = words[1]
if os.path.isfile("/proc/"+pid+"/cmdline") == False:
continue
path = run_cmd(“strings -n 1 /proc/”+pid+"/cmdline | grep roms")
path = path.replace(’/home/pi/RetroPie/roms/’,’’)
if len(path.replace(’"’,’’).split("/")) < 2:
continue
sysname = path.replace(’"’,’’).split("/")[0]
if sysname in arcade:
sysname = “arcade”
romname = path.replace(’"’,’’).split("/")[-1].rsplit(’.’, 1)[0]
elif is_running(“gif”) == True: # Video screensaver (OMXplayer)
ps_grep = run_cmd(“ps -aux | grep mp4 | grep -v ‘grep’”)
if ‘RetroPie’ in ps_grep:
pid = words[1]
continue
continue
sysname = path.replace(’"’,’’).split("/")[-3]
sysname = “arcade”
elif os.path.isfile("/tmp/PieMarquee.log") == True: # Extended ES
f = open(’/tmp/PieMarquee.log’, ‘r’)
line = f.readline()
f.close()
words = line.split()
if len(words) > 1 and words[0] == “Game:”: # In the gamelist-> Game: /home/pi/…/.zip
path = line.replace(‘Game: ‘,’’)
sysname = “arcade”
sleep_interval = 0.1 # for quick view
elif len(words) == 1:
sysname = “system”
if words[0] == “SystemView”:
romname = “maintitle”
else:
romname = words[0]
else:
sysname = “system”
if os.path.isfile("/home/pi/PieMarquee2/marquee/" + sysname + "/" + romname + ".png") == True:
imgname = sysname + "/" + romname
if ingame == "*":
publisher = get_publisher(romname)
if os.path.isfile("/home/pi/PieMarquee2/marquee/publisher/" + publisher + ".png") == True:
pubpath = "/home/pi/PieMarquee2/marquee/publisher/" + publisher + ".png"
if os.path.isfile("/home/pi/PieMarquee2/marquee/instruction/" + romname + ".png") == True:
instpath = "/home/pi/PieMarquee2/marquee/instruction/" + romname + ".png"
elif os.path.isfile("/home/pi/PieMarquee2/marquee/system/" + sysname + ".png") == True:
imgname = "system/" + sysname
else:
imgname = "system/maintitle"
if imgname+ingame != cur_imgname: # change marquee images
kill_proc("omxplayer.bin")
if imgname == "system/maintitle" and os.path.isfile("/home/pi/PieMarquee2/marquee/system/maintitle.mp4") == True:
## for DPI screen
#os.system("omxplayer --loop --no-osd --display 4 /home/pi/PieMarquee2/marquee/system/maintitle.mp4 &")
## for Pi4 hdmi1
##kill_proc("omxiv-marquee")
##os.system("omxplayer --loop --no-osd --display 7 /home/pi/PieMarquee2/marquee/system/maintitle.mp4 &")
kill_proc("led-image-viewer")
os.system("led-image-viewer -C /home/pi/PieMarquee2/marquee/system/maintitle.gif --led-no-hardware-pulse --led-rows=32 --led-cols=64 --led-chain=2 --led-slowdown-gpio=2 --led-gpio-mapping=adafruit-hat &")
cur_imgname = imgname+ingame
else:
f = open("/tmp/marquee.txt", "w")
if pubpath != "":
f.write(pubpath+"\n")
f.write("/home/pi/PieMarquee2/marquee/" + imgname + ".png")
if instpath != "":
f.write("\n"+instpath)
f.close()
if os.path.isfile("/home/pi/PieMarquee2/marquee/custom/" + romname + ".txt") == True and ingame == "*":
os.system("cp /home/pi/PieMarquee2/marquee/custom/" + romname + ".txt /tmp/marquee.txt")
else:
imgpath = "/home/pi/PieMarquee2/marquee/" + imgname + ".png"
if ingame == "*":
if pubpath != "":
imgpath = pubpath+"\n"+imgpath
if instpath != "":
imgpath = imgpath+"\n"+instpath
os.system('echo "' + imgpath + '" > /tmp/marquee.txt')
sleep(0.2)
if is_running("led-image-viewer") == False: # if omxiv failed, execute again
os.system("clear > /dev/tty1")
os.system(VIEWER)
sleep(sleep_interval)
