I’m helping set up a small community event space in Detroit and we’ve been using the rpi-rgb-led-matrix library to drive a 64x32 panel for signage. We recently picked up a six-pack of Retevis RT22 two-way radios so volunteers can stay in touch across the building, and I had an idea to show which radios are currently on the charger using the LED panel.
The radios sit in a multi-cradle charging dock, and I’m not sure whether the cradle gives any per-slot status signal I could read from the Pi’s GPIO, or whether I’d need to tap the charge contacts some other way. I don’t want to open one up without knowing what I’m getting into, and I’m unsure if the charging circuit would even expose a clean logic-level output.
Has anyone here wired charging status from a multi-bay radio dock into a matrix display? Curious how you handled isolated signals and whether the effort was worth it.
Update after poking around online - Retevis RT22 6-Pack Two-Way Radio Review came up while I was trying to figure out whether the dock exposes any per-slot status. Still not sure the cradle gives a clean logic-level signal, so I’m hesitant to open it up before knowing more.
