Requesting help in mapper
I have RGB Matric panel with connections
as
P1–> P6–>P2–>P5–>P3–>P4
and below is its actual matrix placements
P1 P2 P3
P6 P5 P4
Wwhich mapper i can use to be able to use these matrix as one display
Welcome to the forum!
Not sure whether this might be useful, I initially thought it could use a U-mapper but then this suggests you might get a better experience with a Z-mapper, if in doubt maybe (and apologies in advance…) Caude (etc) might be able to advise on the specific use case, and if something doesn’t already exist might generate a mapper you can plug into the library for your exact layout. :thinking:
Please check out the documentation:
