Qiangli Q4 IC-C8325QP+DP32020A-B
Is anyone familiar with this panel? It doesn’t show anything.
Qiangli Q4H19B 80x40 IC-C8325QP+DP32020A-B 1/10 scan
There is no /10 scan panel supported at the moment but it’s smaller than 128x64, so it might work as a 128x64 panel.
Does it work/light up if you treat it as a /32 64 line ABC panel (–led-row-addr-type 3 and 5)?
Why?
There is nothing specific in /10 scan panels
The code does not currently directly support panels that are not powers of 2.
You can try it out, it might work with 128x64 or may need adjustments and you can submit patches as needed :slight_smile:
