Is there a line of code I can change to make the default --led-slowdown-gpio=2 instead of using that command everytime?
The runtime options rgb_matrix::RuntimeOptions has a field gpio_slowdown which you can set before parsing the options. So in this typical start of a program, you’d do it like this:
RGBMatrix::Options matrix_options;
rgb_matrix::RuntimeOptions runtime_opt;
runtime_opt.gpio_slowdown = 2; // <- setting value
if (!rgb_matrix::ParseOptionsFromFlags(&argc, &argv,
&matrix_options, &runtime_opt)) {
return usage(argv[0]);
I’ve now also just added a feature that if the library detects a Pi4, it automatically defaults to slowdown=2, as this seems to be needed most of the time.
So if you update the library from latest git, maybe this will already solve your problem if you’re on a Pi4.
