I’m having an issue where the second panel of both chains that I have, have some flickering/artifacting going on.
My setup:
Raspberry Pi 4B 8GB
Electrodragon v1 or v2 drive board
(4) Adafruit 64x32 4mm Panels
40A 5V Power Supply
When running the 2x2 panel setup (2 parallel chains of 2), the second panel on each chain has some flickering as well as some artifacting on the nearby pixels. There’s also one spot on the end that always shows some red flickering.
My flags used:
--led-cols=64
--led-chain=2
--led-parallel=2
--led-slowdown-gpio=4 (tested all of these and 4 is the only one that displays properly)
--led-pixel-mapper=Rotate:180 (I have it rotated as I'm testing on a bench and am too lazy to flip everything around :P)
--led-show-refresh (program runs at a pretty consistent 200Hz)
I’ve run multiple scoreboard codes (NHL, MLB, NFL) from Github and they all show this same issue.
I’ve also changed out the display driver board with multiple ones of v1 as well as v2.
I also soldered the pins for E-Line to test, and tried the E>4/8>GND as well as E>8/4>GND which in both cases made the problem worse.
I’ve swapped the panels around in different areas and the problem doesn’t follow the panel, but stays consistent no matter what I change around.
It seems to be something that is not hardware related, but I can’t figure this out.
Thanks for any help!
