Your projects sounds very interesting. For my own (LEDarcade) I wanted a scrolling list of Patrons. I wrote several functions to generate text on the fly and display that like an old 80’s terminal, but this time I wanted it to be a bit fancier.
My strategy (based on an example by others) is to generate an image, write the text on the image, then scroll the image.
Because the image is larger than the screen itself (I am using 64x32 LED matrix), I crop the image then display that cropped version. Then I move my pointers down, and crop the original image again but one pixel lower. Then I display that.
I do that until the end of the image.
Examples:
def CreateCreditImage(names):
Buffer = 32
GradientSection = 32
text_y_position = 0
text_padding = 12
image_width = 64
ColorB = 52
TextRGB = (175,175,175)
#Create blank image
image_height = (len(names) * text_padding) + (Buffer *2) + (GradientSection *2) + 13
img = Image.new("RGB", (image_width, image_height), color=(0,0,ColorB))
draw = ImageDraw.Draw(img)
#Draw buffer
for v in range (0,Buffer):
draw.line((0,text_y_position,HatWidth,text_y_position),fill=(0,0,0))
text_y_position += 1
#draw gradient
for v in range (0,GradientSection):
NewColorB = round(ColorB / GradientSection * v)
draw.line((0,text_y_position,HatWidth,text_y_position),fill=(0,0,NewColorB))
#write header
Text = "PATRONS"
fnt = ImageFont.truetype("/usr/share/fonts/truetype/noto/NotoMono-Regular.ttf",12)
header_width, header_height = draw.textsize(Text, font=fnt)
draw.text(
(image_width - header_width) / 2, text_y_position ),
Text,
font=fnt,
fill=(250,250,250)
text_y_position += text_padding
#write patron names
for name in names:
text_width, text_height = draw.textsize(name, font=fnt)
fnt = ImageFont.truetype("/usr/share/fonts/truetype/noto/NotoMono-Regular.ttf",10)
draw.text(
(image_width - text_width) / 2, text_y_position ),
name,
font=fnt,
fill=TextRGB
#draw gradient
for v in range (GradientSection,0,-1):
#Draw buffer
img.save('credits.png')
def ScrollCreditImage(CreditImage,ScrollSleep):
image = Image.open(CreditImage)
image = image.convert('RGB')
width,height = image.size
print("ScrollCreditImage: CreditImage")
print("Image width height:", width,height)
for x in range (0,height - HatHeight):
#print("Cropping image x:", x)
ScreenCrop = image.crop((0,x,HatWidth,x + HatHeight))
TheMatrix.SetImage(ScreenCrop,0,0)
time.sleep(ScrollSleep)
def AdjustBrightnessRGB(rgb,step):
r,g,b = rgb
r = r + step
if r < 0:
r = 0
elif r > 255:
r = 255
g = g + step
if g < 0:
g = 0
elif g > 255:
g = 255
b = b + step
if b < 0:
b = 0
elif b > 255:
b = 255
return r,g,b
These functions are part of the LEDarcade library:
I hope this helps. Reach out if you have any questions.
