Can't set realtime thread priority=99: Operation not permitted. When using the c# wrapper
I’m using the C# wrapper with a web api in .net 7. The first image I want to show on my pixel display with the wrapper works. But every image after that gives the following error
        You are probably not running as root ?
        This will seriously mess with color stability and flicker
        of the matrix. Please run as `root` (e.g. by invoking this
        program with `sudo`), or setting the capability on this
        binary by calling
        sudo setcap 'cap_sys_nice=eip' /home/sharevalue/pixelsharp/bin/Debug/net7.0/pixelsharp
Now, I have to run the app with sudo dotnet run, otherwise it wont work.
Does anyone know what to do to fix my issue?
did you do what the message said?
sudo setcap ‘cap_sys_nice=eip’ /home/sharevalue/pixelsharp/bin/Debug/net7.0/pixelsharp
Yes but the problem is that you have to set that with every request. But I fixed it now by using a Singleton pattern :slight_smile:
Sorry to highjack this… I am trying to get started on this using the C# bindings… but I am having issues just getting the base dll to work correctly… do you have any pointer on how to do it?
